2001 Dodge Truck oil leak
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIKERBARRY
i have an engine oil leak from the adapter between the vacuum pump and the power steering pump. i just installed a new cummins seal kit but i still have the same leak
May 30, 2009 at 4:50 AM
SERVICE WRITER
  • 9,123 POSTS
Not sure of the kit. IS there a shaft with that?
What specific truck and motor do you have?
HAve you cleaned it off to verify the location of the leak?
May 30, 2009 at 1:14 PM
BIKERBARRY
the engine is a 5.9L cummins diesel. everything was cleaned. the adapter is what connects two shafts together.
May 31, 2009 at 6:07 AM
