2001 Dodge Truck Noises when i turn.
129,000 MILES • V8 • 4WD • AUTOMATIC
BLUEJAY75
When i turn my steering wheel to either left or right i have a noise i can best describe to my knowledge as the sound of like a yelping dog, as well as a little bit of grinding noise i was wondering if it was the powersteering gear box?[img:91284b1184]http://www.2carpros.com/forum/automotive_pictures/323498_Picture_021_1.jpg[/img:91284b1184]
Feb 25, 2009 at 12:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Need to inspect your power steering fluid level. Also inspect drive belt around power steering pump to ensure it is tight.
Does this noise only occur when the wheel is cut completely left or right? or during turning at all? If it does it with any slight turn of the wheel and your fluid level is OK, I would suspect a faulty power steering pump.
Thanks for using 2CarPros.com!
Feb 25, 2009 at 6:35 PM
