1998 Dodge Truck On again off again
135,000 MILES • V8 • 2WD • AUTOMATIC
TOOLDADDY40
When tilt steering wheel is in upwared position, turn signals, radio and wipers will not work at all. When steering wheel is in fully lowered position all work well. While moving slowly between both position cliccking noise heard and power to these items sporatic.
Jan 19, 2009 at 9:54 PM
  • 110,248 POSTS
There must be a loose harness plug or damage to the wiring in the steering column. That is where I would start looking. Because the truck has an air bag, you may want to have a qualified mechanic check it because the steering wheel needs removed. You don't want to deploy the airbag.
Let me know what you find.
Jan 21, 2009 at 2:38 AM
