Monday, September 29th, 2008 AT 12:42 PM
2001 Dodge Ram 1500 SLT 2WD. When turning left while driving I get and loud noise and a vibration coming from driver's side front wheel. The faster you go the louder. Noise is only present when steering wheel is turned left. Noise goes away when turned right. Allignment was done resently and power steering pump is new. Checked movement on both front tires when they were jacked up and passenger side front tire had slight movement. Bushings in front end aren't bad looking. What could be possible problems?
