2001 Dodge Truck Engine appears to misfire when cold
132,000 MILES • V8 • 4WD • AUTOMATIC
GLENN1222
When I start my engine it seems to run well. A couple of minutes after it has been running it will sputter/misfire briefly. I put it in neutral and give it gas and the problem goes away and stays away as long as the engine is hot. I replaced the filter/pressure regulator because it started hard also. Now I only have this problem. I have inspected but not replaced the idle air module. Any ideas?
Aug 25, 2010 at 7:03 AM
  • 75,988 POSTS
Hi glenn1222, Welcome to 2carpros and TY for the donation
Do you have a check engine light and when was the last tune-up??
Try checking the idle air control motor,intake air temperature and throttle position sensor-also check the fuel pressure
Aug 25, 2010 at 9:47 AM
GLENN1222
Fuel pressure was at 49psi and constant. After replacing the filter/regulator it is at 53psi and constant.
There is no check engine light now, the code before replacing the filter/regulator was a small fuel leak.
I replaced the cap, rotor, plugs and wires as part of troubleshooting.
How do you test the idle air motor or the air intake temp sensor?
It goes back to normal and stays normal after reving it up on loss of power/misfire. It is only happening about 1 to 2 minutes after starting and lasts 5 to 15 seconds. It would go to normal on its own in about 15 to 20 seconds.
Aug 25, 2010 at 1:41 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve and see what happens
https://images.2carpros.com/forum/automotive_pictures/12900_iac_motor_1.jpg
Aug 25, 2010 at 2:03 PM
GLENN1222
I replaced the idle air controller and still have the same problem. Any ideas?
Sep 9, 2010 at 9:45 AM
  • 75,988 POSTS
Is the check engine light coming on when problem reappears?
Other causes, that can contribute to the misfiring problem
Defective spark plug.
Inadequate spark/coil,defective spark plug wire.
Lack of compression
False air leakage.
Faulty fuel injectors.
Insufficient fuel pressure.
Contaminated fuel.
EGR valve that is leaking.
Oxygen sensors.
Throttle Position sensor
Idle air control valve
Sep 9, 2010 at 9:53 AM
GLENN1222
No check engine light, replaced the idle air control valve, replaced the filter/regulator (Solved the hard starting problem), changed the plugs, cap, rotor, plug wires. This only happens for a few seconds and after running for about a minute. If you floor it the problem goes away and doesn't come back.
Sep 9, 2010 at 10:53 PM
  • 75,988 POSTS
Test the throttle position sensor's closed idle and wide open throttle voltages-
Sep 10, 2010 at 12:39 AM
