2001 Dodge Truck 3500 Diesel ABS
2001 DODGE TRUCK
116,000 MILES • 6 CYL • 4WD • MANUAL
RICHARD HALL
ABS light comes on some times followed by stiff pedal .Sometimes brake pedal goes to floor and you can hear the abs working but getting stopped is a problem and times the brakes are fine.it just came from mechanics shop they replaced everything on the outside of truck but nothing under the hood.
Dec 12, 2007 at 10:54 AM
SERVICE WRITER
  • 9,123 POSTS
Need to get a scanner hooked up that can read both codes and the readout from the sensors. It sound like a speed sensor is failing to communicate with the BCM and it thinks it is on ice or skidding, thereby applying the ABS.
Dec 12, 2007 at 11:26 AM
