Are the threads in the jam nut right or left handed that is located directly behind the fan clutch
thanks
Sep 12, 2009 at 6:00 AM
✓Experienced Mechanic
Turn counter clockwise to remove. If you are removing the fan clutch, the best way I found it to leave the belt on, jam the pulley as best you can, place the wrench over the nut and smack it about 4 or 5 times with a dead blow hammar. It will come loose.
Oct 7, 2009 at 3:51 AM
