2001 Dodge Truck
C. KOENIG
Engine problem
2001 Dodge Truck Engine Size unknown Four Wheel Drive Automatic 62300 miles
I OWN A 2001 DODGE 1 TON DUALLY WITH A V10. A COUPLE MONTHES AGO I LEFT THE HOUSE WITH A TRAILER AND THE TRUCK WAS TERRIBLY UNDERPOWERED. I TURNED AROUND AND POPPED THE HOOD. THE RIGHT EXHAUST MANIFOLD WAS GLOWING CHERRY RED SO I REMOVED THE CATTALITIC CONVERTER. THIS DID NOTHING SO I REPLACED THE O2 SENSOR ON THAT SIDE STILL NO GOOD. THE TRUCK SMELLS TERRIBLY OF RAW FUEL WHEN I TRY TO DRIVE IT. IT IS SO UNDER POWERED THAT IT WILL NOT EVEN PULL ITSELF AWAY FROM THE FROZEN ROCKS.
Feb 6, 2008 at 9:03 AM
BLACKOP555
  • 10,386 POSTS
Check for spark at every cylinder on the right side of the engine, let me know what you find.
any check engine light?
Feb 6, 2008 at 11:16 AM
