2000 Dodge Truck TRUCK SHUTS DOWN
2000 DODGE TRUCK
186,000 MILES • V8 • 4WD • AUTOMATIC
MITCH STEVENS
WHEN DRIVING OR IDELING TRUCK WILL JUST SHUT DOWN WILL HAVE TO WAIT A WILE TO GET STARTED AGAIN SOMTIMES A SHORT TIME OTHERS UP TO 30 - 45 MINS DURING THE TIME THAT IT WONT START MANY ATTEMPTS TO START ENGINE WIL JUST TURN HAVE NOTICED THAT GAUGES WONT WORK AS WELL THEN FINNALLY YOU TURN KEY AND SEE GAS GAUGE RISE AND TRUCK WILL START ALL LIGHTS AND ELECTRICAL IN CAB ARE NOT EFFECTED AFTER STARTING TRUCK WILL REPETE THIS SEVERAL TIME SO I JUST PARKED IT
NOTICED THAT TRUCK DOES THIS MUCH MORE OFTEN IN WARM WEATHER HAD FRIEND LOOK AT IT DURING TIME OF MALUNCTION CHECKED FUSES MOVED WIRES AROUND EVEN ENERGIZED THE COIL
WITH NO EFECT ALSO HAVE REPLACED THE CRANK SHAFT POSITIONING SENSOR PLS ANY IDEAS THAT
MAY HELP IN RESOLVING THIS MATTER WOULD GREATLY APRESHEATED THX VERY KINDLY MITCH STEVENS
Nov 17, 2009 at 12:23 PM
MITCH STEVENS
[quote:a30458a84b="Mitch Stevens"]Electrical problem
2000 Dodge Truck V8 Four Wheel Drive Automatic 186000 miles
MAY HELP IN RESOLVING THIS MATTER WOULD GREATLY APRESHEATED THX VERY KINDLY MITCH STEVENS[/quote:a30458a84b]
Nov 17, 2009 at 12:28 PM
BMRFIXIT
  • CERTIFIED EXPERT
  • 19,053 POSTS
Check relays
may be mark them and switch around
Nov 17, 2009 at 4:11 PM
