2000 Dodge Truck Oil pressure gauge
12,200 MILES • V8 • 2WD • AUTOMATIC
CRASCHKE
I noticed suddenly that the oil pressure gauge dropped tp near nothing at idle (the alert came on), but when I revved it up it came back up to the 40+ psi range. This happened twice in a row. I also noticed at the same time suddenly there was a slight knock in the engine (like the sound of too low octane gas) at higher speed, but that was sporadic. I drove the truck home and parked it. It's a third vehicle I use just for hauling. I'm always afraid of screwing up the engine when the oil pressure goes to to nothing. Should I have it towed to a shop, or is it safe to drive it there (about eight miles)? Do you think it's anything other than possibly replacing the oil pump, which may be bad?
Oct 12, 2008 at 9:17 PM
  • 31,937 POSTS
Hi there,
It would be safer to tow it in to the workshop, you may have a pump or a pressure relief valve problem, this should be investigated before you drive it again.
Mark (mhpautos)
Oct 12, 2008 at 9:32 PM
CRASCHKE
Thanks a lot. You confirmed my instincts.
Oct 12, 2008 at 9:59 PM
