changed the fuel pump twice and it still will not run
100,000 MILES • V8 • 2WD • AUTOMATIC
TFRANKLIN
I have changed the fuel pump twice and it still will not run. What else could be the problem
Mar 8, 2008 at 7:36 AM
SQM
  • 6,383 POSTS
When you turn the key on, does the fuel pump come on?
If the pump does not come on, then it could be a bad relay or faulty wiring.
First check the relay, it is located in the under-hood fuse box (see diagram below).
Here is a guide of how to test the relay:
If the relay is good, then check to see if there is power to the fuel pump harness. Having no power to the connector means there is a short in that circuit.
If the fuel pump comes on but you are not getting any fuel to the injectors it could be due to a restriction in the fuel line, clogged fuel filter or a bad fuel pressure regulator.
Oct 28, 2021 at 7:19 AM
