Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Truck
Exterior Light
Turn Signal
2000 Dodge Truck blinker
2000 DODGE TRUCK
11,500 MILES • 6 CYL • 2WD • AUTOMATIC
DMCGUFF1
MEMBER
1 POST
blinkers will work correctly the first few times you use them. Then they will stick and the light will light up solid (no blinking action) !!!
Oct 26, 2009 at 8:57 AM
HMAC300
Experienced Mechanic
check all your bulbs when it does this, you may have one burnt out. Otherwise replace the flasher.
Nov 6, 2009 at 6:18 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
