i have a problem with getting my 2000 dodge truck started, i checked the relay,fuses brakers, as well as had the starter tested it was alright,yet when you turn the key to start i have dash lights and you here the relay noise in the front of the truck nut the truck will not turn over to start at all have checked all the connectors.also i have no check engines codes so can you tell me what might be wrong. thank you R.W.Steward
Mar 28, 2009 at 6:55 AM
