2000 Dodge Truck
140,000 MILES • V8 • 4WD • AUTOMATIC
B.NASHJR
When I start my truck first thing in the morning it turns over but doesn't start.I have to turn it over about six times before it starts.When it starts it sputters and putts before it runs with a heavy smell of fuel.Once it is running and I go to work it starts fine the rest of the day. The following morning it does the same thing. What could cuase this?
Feb 8, 2008 at 11:32 AM
BLACKOP555
  • 10,386 POSTS
does it matter if it is warm outside in the morning or cold in the morning?
Feb 8, 2008 at 11:44 AM
B.NASHJR
It's been cold and damp
Feb 8, 2008 at 12:00 PM
BLACKOP555
  • 10,386 POSTS
is it possible you can get it in a dry heated garage for a night or two ?
Feb 8, 2008 at 12:17 PM
B.NASHJR
No I do not know anyone with a heated garage and I need the truck becuase it is my only source of transportation
Feb 8, 2008 at 12:24 PM
BLACKOP555
  • 10,386 POSTS
really dont wanna do this as it will cost you extra money.
first we will treat it for a lack of fuel pressure and a cold start first.
first change the coolant temp sensor and see if that fixes it. if not right after the vehicle is turned off clamp off the in and out lines of fuel rail on a rubber part of the hose then when the vehicle is ready to be started the next day turn the key to the on position then remove the clams then turn it off and then back on do this about 5 times.
then crank it. let me know what happens.
Feb 8, 2008 at 1:01 PM
