1999 Dodge Truck transmission problem
RACERD632
Transmission problem
1999 Dodge Truck V8 Two Wheel Drive Automatic 170.00 miles
i drove to wrok today and everything was fine. I stop at a light. when light is green i cannot go. it revs up but acts like it is not in gear. it went on for about 5 seconds before it started moving and this continued at every light till i got back home. the fluid level is good and clean. any suggestions or am i screwed?
Dec 4, 2007 at 12:33 PM
ADVANT1
not sure if this is the same problem--but I had a Ford Ranger do a similar thing--took it in, and it was in the brain/transmitter problem--cost me about $350.00 to fix--it would shift, but always seemed like it was slipping--I ended up shifting it manually, Low, 2nd High until they fixed it--been okay for 6 months since--cheaper than a transmission--
good luck
advant1
Dec 4, 2007 at 1:24 PM
