1999 Dodge Truck Shut off
1999 DODGE TRUCK
198,000 MILES • V8 • 4WD • MANUAL
99 RAM2500
It just shuts off as you are driving. It will crank but not start for a few minutes after it shuts off. The Gagaes will frreeze for a bout 10 -15 sec and a NO BUS will flash onthe trip odometre. As soon as the gages un-freeze the NO bus will be replaces with the trip odometer reading. I replaced the ASC relay thinking that was it but still does it . Pull the relay when the truck is run is the closest to simulation what it does when it shuts off. It just goes dead no hesation or shutter.
Jul 18, 2008 at 1:08 AM
BMRFIXIT
  • 19,053 POSTS
no bus is no communication check wiring harness check fuses and connections
Jul 25, 2008 at 11:00 PM
