1999 Dodge Truck Power loss
RZERANKO
  • 1999 DODGE TRUCK
  • V8
  • 4WD
  • 150,000 MILES
I have started experienceing a power loss. When I try to speed up, it kicks into passing gear, my rpms run high while trying to maintain speed. My check engine light sometimes will flash and once it stayed on. I scanned and it told me I mis-fired on #1 cylinder. I checked and the spark was fine. I went ahead and replaced the plugs, wires, rotor and cap but still have the problem. Any ideas?
Friday, January 4th, 2008 AT 3:53 PM
POKEYS_MAN
  • 7 POSTS
Good luck with yours. I have similar problems with my '95 but no lights. From 45 - 60 mph the truck shakes when the transmission goes into lockup. I've done a complete tuneup, and I'm told the problem is compression and I need 2 new heads. Someone suggested wiring a switch such that you can select (or deselect) overdrive.
Wednesday, January 16th, 2008 AT 7:32 PM
