firing order
1999 DODGE TRUCK
80,000 MILES • V8 • 2WD • AUTOMATIC
KRAMEL
need to know the firing order for a ram 1500 pickup with a 5.9 lit V8. Also, need the location of #1, #2, and so on, left or right from front of engine. Need the rotation direction(clockwise or counterclockwise). Changed cap/rotor and as careful as I tried to be, got 1 out of order fighting that heater hose.
Oct 5, 2010 at 5:05 PM
Here is the engine firing order
https://images.2carpros.com/forum/automotive_pictures/12900_fo_160.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_f1_6.gif
Please let us know if you need anything else to get the problem fixed. Cheers
Oct 5, 2010 at 5:12 PM
PWINEGAR66
Need to know firing order for distributor cap
Oct 10, 2020 at 9:51 AM (Merged)
https://images.2carpros.com/forum/automotive_pictures/12900_fo_31.jpg
ROBERTB357
Electrical problem
1996 Dodge Truck 6 cyl Two Wheel Drive Automatic
What is the firing order for 1996 Dodge Ram 1500 V6
See below
https://images.2carpros.com/forum/automotive_pictures/12900_39_1.jpg
See below
Oct 10, 2020 at 9:52 AM (Merged)
TAPPEDOUT56
Electrical problem
1989 Dodge Truck V6 Two Wheel Drive Automatic 148936 miles
I replaced my distributer cap and plug wires incorrectly. How do I correct the wires for proper firing order.
Note: The donation page will not except a donation.
I tried three times.
MERLIN2021
  • 17,250 POSTS
The order is 1 2 3 4 5 6!
https://images.2carpros.com/forum/automotive_pictures/62217_FO_1.jpg
Try the donation again, or mail a check or MO to the address below! Thanks...
CAROL SIMPSON
Engine Mechanical problem
1984 Dodge Truck V8 Two Wheel Drive Automatic
WHAT IS THE CORRECT FIRING ORDER FOR A 360 CU IN ENGINE
JDL
  • 16,098 POSTS
Welcome to the forum. My info showed this.
https://images.2carpros.com/forum/automotive_pictures/170934_360_firing_order_1.jpg
