1999 Dodge Truck cooling
1999 DODGE TRUCK
EDS AUTO
  • 5 POSTS
Air Conditioning problem
1999 Dodge Truck V8 Four Wheel Drive Manual
its a crew cab when heat or air is on driver side is cold and the pass side is hot
Sep 7, 2010 at 8:16 AM
WRENCHTECH
  • 20,761 POSTS
Is it a dual temp control system?
Sep 7, 2010 at 8:53 AM
EDS AUTO
  • 5 POSTS
yes is a control or mybe its a bled door
Sep 8, 2010 at 10:01 AM
WRENCHTECH
  • 20,761 POSTS
Is there an answer to my question in that assortment of misspelled words that make no sense?
Sep 8, 2010 at 10:21 AM
EDS AUTO
  • 5 POSTS
yes it has
Sep 8, 2010 at 10:36 AM
WRENCHTECH
  • 20,761 POSTS
The heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Sep 8, 2010 at 10:43 AM
EDS AUTO
  • 5 POSTS
how much of the dash need to come out
Sep 8, 2010 at 10:50 AM
WRENCHTECH
  • 20,761 POSTS
I just went through multiple sources and there are no Ram pickups with dual temp controls so you need to verify your info.
Sep 8, 2010 at 11:17 AM
EDS AUTO
  • 5 POSTS
sorry went out garage to check it out.its not if you got on vents whit heaton driver side cold and pass side hot and if you switch it to the floor. im working
3 diffrent cars at same time
Sep 8, 2010 at 11:40 AM
