1999 Dodge Truck conversion
1999 DODGE TRUCK
175,000 MILES • V8 • 4WD • AUTOMATIC
TLEWNORMCHRIS
I have a 99 dodge ram 1500 with the 5.9L V8 in it I believe that the overdrive clutch is goin out because it has towed some heavy trailers and the transmission is starting to grind upon acceleration. I was wondering if it is possible to put a heavier transmission from the 99 dodges such as a 3/4 ton or a 1 ton's transmission on it if so where would be the cheapest place to get a used one, and when replacing the transmission would I have to pull the motor on this specific model
Nov 5, 2009 at 12:38 AM
HMAC300
  • 48,601 POSTS
they are probably the same, just built a little different. when you get yours rebuilt they can probably do the same for you.
Nov 6, 2009 at 6:16 AM
