1999 Dodge Truck abs and brake light
1999 DODGE TRUCK
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
TODD TURNER
Speedometer only works >15 mph and both abs and brake light stay on- all happened at same time. Replaced speed sensor on transmission- no change.
Jun 15, 2008 at 11:20 AM
BONNER
  • 5 POSTS
[quote:da2b545973="todd turner"]Brakes problem
1999 Dodge Truck 6 cyl Two Wheel Drive Automatic 132000 miles
Speedometer only works >15 mph and both abs and brake light stay on- all happened at same time. Replaced speed sensor on transmission- no change.[/quote:da2b545973]I had this problem with my 1999 ram it was the real wheel speed sensor locatedon top of the rear differential (pumpkin) not hard to change I did it and I'm no mechanic. Make sure you buy it fom the Dodge dealer the one they had at autozone didn't look like the original part.
Jun 24, 2008 at 3:26 PM
