1999 Dodge Truck
1999 DODGE TRUCK
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
GARYMK1962
I have a diesel 5.9 cummins it will start but when i push on the fuel pedal it does nothing. The RPMs do not increase. Is this a throttle body problem? Is there anyway to test the throttle body?
Feb 8, 2010 at 12:43 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,308 POSTS
Throttle bodies are a gas engine thing. Diesels use injector pumps and direct injection. Is it cold enough that the fuel could be gelled?
I've heard the lift pump could cause this problem. Hopefully someone more knowledgeable will add a reply.
caradiodoc
Feb 11, 2010 at 3:47 AM
