1998 Dodge Truck Wheel joint
OKIECOONASS
Drive Train Axles Bearings problem
1998 Dodge Truck V8 Four Wheel Drive Automatic
I need the size of the socket on the drivers side to remove the wheel joint
Aug 27, 2009 at 5:43 AM
  • 110,248 POSTS
Wheel joint? Are you refering to the nut on the hub bearing? I would have to check for sure, but I believe it is around 1 1/4" If metric, try around 30mm.
Oct 7, 2009 at 5:15 AM
