Motor still runs, dont know if its gasket,heads or block. How would I test for cracked block?
May 20, 2009 at 11:17 AM
✓Experienced Mechanic
Hi there,
There is no easy way to check for a cracked block,you will have to get it crack tested that will mean removal and full strip down, i would be thinking head or gasket, get a head check done, this is a test that picks up exhaust in the cooling system, a sure sign of head or gasket failure, start here.
