1998 Dodge Truck No Sparks
1998 DODGE TRUCK
90,000 MILES • V8 • 4WD • AUTOMATIC
LEO041574
Hi, I have a 1998 dodge 1500 318 engine. I just put in a used engine, once done i started the truck, drove it around the block to test it, ran fine. When i got home i put in a new thermostat. Tried starting it again and it would not start. Fuel is getting into the truck but no spark. Replaced the crank sensor, cap, rotor and the ignition coil, still no spark. I'm going crazy can't figure it out. Thank you for any advice or help that you can assist me with.
Mar 24, 2010 at 2:11 AM
Do you have battery voltage on the coil positive terminal if so -Check and test the distributor pick-up coil and ignition control module-
Mar 24, 2010 at 10:22 AM
