1998 Dodge Truck joe tafia.
JOE T
1998 Dodge Truck V8 Four Wheel Drive Automatic
i have a dodge truck 1500 169000 miles the next morning went to start it it just crank but it wont turn over and went and rent a code test chart and it says everything passed so im kind a stuck what to do now it might be the fuel filter im just guessing i need your help.
Jan 11, 2010 at 9:37 AM
  • 75,988 POSTS
Cranks and no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 11, 2010 at 11:51 AM
