Headlights Not Working(Light Bulbs Work)
188,000 MILES • V8 • 4WD • AUTOMATIC
PUMPED_316
. My headlights are not working. I replaced the fuse, when i pull the light switch only the parking lamps and the brake lights come on, my daylight running lamps work. I checked the light bulbs so what can be the problem.My Highbeams will also not stay on when i pull the lever.
Feb 22, 2008 at 12:42 PM
MEEJOE
I have the same problem with my headlights. Parking lights work, but no low beams or high beams. Did you ever find out what the problem was?
Thanks, Joe 1997 Dodge Ram 1500
Apr 1, 2008 at 2:41 AM
LSHIETS
  • 0 POST
Mine did that and I had to replace the headlight switch... all good now
Mar 25, 2019 at 4:24 AM
WRONG WRENCH
Electrical problem
1998 Dodge Truck V8 Two Wheel Drive Automatic
my head leghts went out i found out its was the switch so i put new ones in, but now i have head lights but no runing lights and no dash lights. but when i push the lights in a little bit the dash lights com and i have runing lights but no head lights?
Mar 25, 2019 at 4:25 AM (Merged)
CH112063
  • 1,320 POSTS
I'm sorry, you installed a new headlight switch and they work now but what are you pushing to get parking lamps? I mean parking lights. Which lights?
THIS IS MIKE
  • 686 POSTS
Replied on November 20, 2009
Even new parts can be broken or bad. By your description the switch is at fault. If you have the wiring schematic, you could check the switch with a DVOM' (Digital volt ohm meter). With the switch in the full on position, check the continuity of the switch. If you find an open circuit that is supposed to be closed, return the switch and try another one.
Answered by 1dodge2
JOHNBOY1975
when you're driving down the street in your headlights are on they start flashing for no reason and then you go to click the high beams on and you lose the headlights only high beam and low beam and cannot get them to come back on what would cause that and all the fuses are good for the headlights???
HOMER1967
  • 875 POSTS
based on your description and the information you have provided I would first try the multifunction/headlight switch.
JOHNBOY1975
it was the switch thank you.
