1998 Dodge B2500 Van hesitation problem
PRO
1998 Dodge B2500 Van, 5.2L, Auto, Air, 150,000 miles
Problem #1 - Each and every time the van is started and accelerated to any low speed, it hesitates or "stumbles" for about 10 seconds. It happens only once and when the engine is hot or cold.
Problem #2 - Accelerating from 50-65mph, on the level w/ no load or AC, takes 15-20 seconds. On a hill or with a load, "pinging" is prevalent. I use 89 octane gas.
Background - The ECM (engine control module, CAT, and fuel pump are new. The ECM failed, pouring gas into the engine, clogging the CAT. I been assured my the mechanic that the timing is on and there are no error codes. Problem #1 precedes the ECM replacement. Problem #2 started with the ECM/CAT replacement.
Sep 11, 2007 at 11:24 PM
WRENCH
  • 57 POSTS
An easy test is try the 91 octane or what ever high octane you have, see if this helps, one more thing to try is feel how much exhaust is coming out does it feel pretty strong or hardly anything (carefull it will be hot). If the better fuel makes a difference then recheck that timing. If there is not a lot of pressure coming out of the exhaust need to follow up on what they did to that exhaust.
Sep 18, 2007 at 1:09 PM
