1997 Dodge Truck tail light
262,000 MILES • V8 • 2WD • AUTOMATIC
CNAVARRO79
No tail lights. A year a go had wiring replaced because the truck lost all lighting. and now i lost the tail lights and dash lights What else can do
Jan 11, 2010 at 6:26 AM
JDL
  • 16,098 POSTS
Welcome to the forum, check fuse 18-- 15 amp in the fuse block. Use a testlite on the circuit, should be hot all the time. If that checks out, check feed to and from the headlamp switch. Pink wire with red tracer is feed to the switch. Black wire with yellow tracer is feed from the switch, with the switch turned on.
Jan 11, 2010 at 7:47 AM
