1997 Dodge Truck slipping
117,000 MILES • 6 CYL • 4WD • AUTOMATIC
RIPKURL1080
i have a dodge 2500 cummins diesel. when i drive it and it gets to around 2000 rpms, it seems to slip and the rpms only go up and down...while i slow down and block cars...haha. any ideas? trans fluid is full and i'm not a mechanic, so i'm stuck. thank you for your time. -john
Aug 3, 2008 at 9:17 AM
MASTERTECHTIM
  • 4,750 POSTS
john these transmissions have solenoids and pressure sensors in them that go bad often, have it checked out by a tranny guy and see if he can run a scan test on it and find out if its a solenoid or sensor.
Aug 3, 2008 at 10:23 AM
JODY TANNER
use a small scan tool to read the codes, if there is a governor press sensor code or a transducer code replace them as a set . there is a techtran mnual that will show you how to remove the valve body and replace those solenoids on skribd.com
Aug 10, 2008 at 7:18 AM
