1997 Dodge Truck power steering failure
416 RIGBY
Steering problem
1997 Dodge Truck V8 Two Wheel Drive Manual
'97 3500 Cummins
drove, parked, next day started no power steering. Resivour full, no leaks, no noise, no dead cats under the hood hahahaha-
Apr 20, 2009 at 2:32 AM
  • 110,248 POSTS
HI
IS there any noise coming from the pump? If you open the PS cap, do you see the fluid circulating?
This is a tough one to identify not being there, but I'll try to help.
Apr 22, 2009 at 9:29 AM
416 RIGBY
pulled the spool valve at the pressure outlet side of the pump, screen was almost blocked. Cleaned, replaced, filled, started, lock to locked steering twice, shut down, refilled, works great. The "big red book" made no mention of this screen in the troubleshooting.
Thanks again for your help, I won't hesitate to use you folks again.
Steve
Apr 22, 2009 at 9:54 AM
  • 110,248 POSTS
I'm glad it's fixed.
Apr 22, 2009 at 10:15 AM
