1997 Dodge Truck Changing front bearing and seal on front a
176,000 MILES • V8 • 4WD • AUTOMATIC
J.ROW
How do i change the front bearing and seal the front left axle
Apr 18, 2010 at 12:48 AM
HMAC300
  • 48,601 POSTS
it's like any other 4 wheel dirive. You have to pull the locking unit out then your brake caliper and mount. then you have to undo the wheel bearing nuts pull that all apart, knock out the inner bearing if it's not a sealed unit, replace and rpack the bearings and reinstall everything in reverse order. You can also get a 3 day manual on the site here for $10 and it will give you step by step.
Apr 24, 2010 at 7:57 AM
