1997 Dodge Truck alternator intermittent charging
326,000 MILES • 6 CYL • 2WD • MANUAL
RUT145
my 5.9 diesel will quit charging when im driving if I open the hood and tap on the black box, that is the electrical connection to the back of my alternator, it starts charging again I thought this was the voltage regulator but u cant buy one. so i looked at your forum and it says the VR is in the puter so what is going on? my alt. tests fine on the machine at the parts store. thank you in advance rut
Oct 17, 2008 at 11:37 AM
MERLIN2021
  • 17,250 POSTS
It is true that the voltage regulation is done by a circuit in the PCM, but if you can tap on the back of the alternator and it starts charging, it must have a defictive brush or rectifier inside, or a loose connection, did you tap on it while bench testing it? I dont think the PCM would feel the tapping on the alt!
Oct 18, 2008 at 12:41 AM
RUT145
i changed the alt and found a replacement contact block and now when i start the truck itwill charge for 10 secs then drop out then do this again 18 ttimes then it keeps charging......so far so good but i havent driven yet will find out tommorow is this cycling normal i dont remember it doing this before
Oct 28, 2008 at 3:28 PM
MERLIN2021
  • 17,250 POSTS
Not really normal....buit remember it is a rebuilt, try another one!
Oct 30, 2008 at 8:39 AM
