1997 Dodge Truck
PFB32
Engine Mechanical problem
1997 Dodge Truck V8 Four Wheel Drive Automatic
my 97 dodge 4wd truck idles iradicly and dies when i put it in gear
Jul 30, 2010 at 6:57 PM
  • 31,937 POSTS
HI there,
I will need a model and engine size please.
mark (mhpautos)
Jul 30, 2010 at 7:24 PM
PFB32
its a 97 dodge truck 4wd with a 360 it idles erracticaly and dies when i put it into gear
Jul 30, 2010 at 7:27 PM
  • 31,937 POSTS
5.9 litre petrol or diesel?
sorry it will make a difference to what the problem can be.
mark,
Jul 30, 2010 at 7:38 PM
PFB32
its a 360 gas motor
Jul 30, 2010 at 7:40 PM
  • 31,937 POSTS
OK,
The engine idle is not manually adjustable, it is controlled by the engine management system, what you can do is clean the throttle body, check that there are no vacuum leaks, scan for any unresolved fault codes, clean the ICM, this may require a new idle control motor, start here.
mark (mhpautos)
Jul 30, 2010 at 8:37 PM
