1996 Dodge Truck Power and performance
1996 DODGE TRUCK
52,000 MILES • V8 • 4WD • AUTOMATIC
LIONHEART00007
Hi, My ram seems to be lacking power, should the button for the o/d be turned on...it is unlit so I assume it is off. Have changed dist.cap, rotor, plugs wires, plugs,
have installed airaid cold air and throttle body spacer, have installed a flowmaster catback exhaust, have changed oil and filter, running 10W-30 Synthetic, have changed transmissin fluid and filter, have redone front brakes, tierods, track bar, and ball joints plus wheel hubs. Still.... it seems like it is lacking power...when i step on the gas, it takes a gradual incline to get speed up, on my other truck...when i step on it, it spins tires but not on the 96 with a 5.2. Is there anything else i should check to get a better throttle response, \Thanks
May 25, 2009 at 9:14 AM
BMRFIXIT
  • 19,053 POSTS
Check and replace coil
do a fuel pressure test
check O2 sensors
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 29, 2009 at 10:08 PM
