1996 Dodge Truck Lights
1996 DODGE TRUCK
246,000 MILES • V8 • 2WD • AUTOMATIC
HUNTER9112
The dashboard lights that illuminate the instrument panel during the night quit working. As well as the normal daytime lights and tail lights when you pull out the light switch the first time, the bright and headlights work fine when it is pulled out to the second level outwards... I tried to put a new switch in and it still continues... Is there a certain fuse I should be checking/replacing???
Jul 31, 2009 at 6:21 AM
DR LOOT
  • 2,311 POSTS
there are no fuses for the circuit, the only problem it can be is the dimmer switch for your lights which is on the left side of the column, try activating that several times to see if you can get your headlights working again if they do do not activate your dimmer switch again until you replace it.
Jul 31, 2009 at 2:10 PM
