1996 Dodge Truck help
20,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAN STAICH
At idle speed and turning tight i feel and hear chatter coming from the rear wheels. I walked next to truck and felt it thru the tire. I jacked up the rear and checked the wheels for play (none) pulled the tire and drum to check for sticking brakes. I replaced a leaky brake cylinder a few weeks ago so i thought it may be faulty. I do not think that is the problem.
Thanks
Dan
Jul 19, 2010 at 1:49 AM
DR LOOT
  • 2,311 POSTS
the chatter sound that you are hearing may be several things a bad U-joint, differential problems, but I think it's a front axle U-joint, that is a common occurrence on this particular truck.
Jul 21, 2010 at 5:24 AM
