1996 Dodge Truck engine lacks power
237,000 MILES • V8 • 2WD • AUTOMATIC
BRUCE NEUBAUER
truck idles fine, will not take any power, it boggs down and quits.
Oct 24, 2010 at 4:42 AM
  • 75,988 POSTS
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 24, 2010 at 3:40 PM
