1996 Dodge Truck alot of problems
1996 DODGE TRUCK
262,218 MILES • V8 • 4WD • AUTOMATIC
SLAYER001
ok well my truck it has a leak well theres a rear diff leak and a front diff leak is there any way to repair that
i have a transfer case leak will it effect me even if i have it in 2wd and not 4wd cuz i no i need to replace my ujoints for the front?
and how would u fix an rear engine leak
thnx guys
Mar 7, 2009 at 4:21 PM
  • 110,240 POSTS
Hi:
Can you describe where the leaks are coming from? Also, keep the transfer case full. Regardless if you are in 2wd or 4wd, you will damage it if it runs empty.
Let me know,
Mar 13, 2009 at 3:49 AM
