1996 Dodge 4x4 1500 318
BIGDADDYWEST
  • 22 POSTS
When i drive my pickup it starts runing rough like its starving for fuel then starts smoking out the tail pipe.What would be causing this. :?:
Sep 15, 2007 at 11:16 AM
WRENCH
  • 57 POSTS
Need some more info if you could, does it do this all the time, what color is the smoke, does the engine light come on, is it hard to start.
Sep 18, 2007 at 12:59 PM
BIGDADDYWEST
  • 22 POSTS
[quote:eb10e10b57="wrench"]Need some more info if you could, does it do this all the time, what color is the smoke, does the engine light come on, is it hard to start.[/quote:eb10e10b57] It is not hard to start and the smoke is black.And the check engine light is on.It dont smoke all the time it just does it when the pickup starts cutting out about 70 mph.
Sep 19, 2007 at 11:34 AM
WRENCH
  • 57 POSTS
It sound like your ignition is cutting out thats the black smoke (raw fuel thats not getting burned up), and with the engine light comming on same time. So its not starving for fuel like you thought but either getting too much fuel or not able to burn the fuel its using. Next question is you say it does it at 70 mph or could it be doing it at a certian rpm. Now your truck is a '96 so it might be able to read engine troulble codes with out code reader, try this with the key switch turn ON-OFF-ON-OFF-ON dont wait to long between cycles the check engine light will then flash a code (have pen and paper ready to write down with) count how many blinks of light, if more than one code than there be about 4 to 5 second delay between. (example one flash pause four flashes 5 second pause two flashes pause two flashes = code 14 for the first and code 22 for the second)
Sep 19, 2007 at 2:13 PM
BIGDADDYWEST
  • 22 POSTS
[quote:f74bdc8bcd="wrench"]It sound like your ignition is cutting out thats the black smoke (raw fuel thats not getting burned up), and with the engine light comming on same time. So its not starving for fuel like you thought but either getting too much fuel or not able to burn the fuel its using. Next question is you say it does it at 70 mph or could it be doing it at a certian rpm. Now your truck is a '96 so it might be able to read engine troulble codes with out code reader, try this with the key switch turn ON-OFF-ON-OFF-ON dont wait to long between cycles the check engine light will then flash a code (have pen and paper ready to write down with) count how many blinks of light, if more than one code than there be about 4 to 5 second delay between. (example one flash pause four flashes 5 second pause two flashes pause two flashes = code 14 for the first and code 22 for the second)[/quote:f74bdc8bcd] The codes that i got from my truck are codes 12,43,51,27,24.could one of these be the problem.I put all new injectors,plugsand wires and it still does it?.
Sep 19, 2007 at 2:49 PM
WRENCH
  • 57 POSTS
Okay #12 is nothing(just means you disconnected your battery at some point) #24 is your t/p sensor show to high a volt good place to start, and # 27 is your #1 injector not responding (since you replaced that I would double check) #51 is oxygen sensor (probley becouse how bad its running) #43 is your ignition coil, So check your t/p sensor than you #1 ignition coil. Oh t/p sensor is throttle position.
Sep 19, 2007 at 3:31 PM
BIGDADDYWEST
  • 22 POSTS
[quote:8d246b5c3e="wrench"]Okay #12 is nothing(just means you disconnected your battery at some point) #24 is your t/p sensor show to high a volt good place to start, and # 27 is your #1 injector not responding (since you replaced that I would double check) #51 is oxygen sensor (probley becouse how bad its running) #43 is your ignition coil, So check your t/p sensor than you #1 ignition coil. Oh t/p sensor is throttle position.[/quote:8d246b5c3e] I put a new t/p/on and checked my #1coil and it helped for a minute now it dont have no power at all. it idles good but when you give it gas it bogs down?
Sep 23, 2007 at 10:44 AM
WRENCH
  • 57 POSTS
You might check that T/P sensor again, I am not sure how you checked it before but if you could recheck with the connector attached to the sensor using a volt meter the center wire is your output terminal, with positive lead to that wire and negative to ground, with ignition on but not engine not running, throttle position closed should have 200 millivolts or more and at wide open throttle you should have less than 4.8 volts and voltage should increase gradually as the throttle is opened. Also T/P sensor when put on should be able to move a few degrees, if it doesnt that try to put on outside of socket tangs than there should be a little tension when moved.
Sep 24, 2007 at 9:38 AM
BIGDADDYWEST
  • 22 POSTS
[quote:d06a7d8b89="wrench"]You might check that T/P sensor again, I am not sure how you checked it before but if you could recheck with the connector attached to the sensor using a volt meter the center wire is your output terminal, with positive lead to that wire and negative to ground, with ignition on but not engine not running, throttle position closed should have 200 millivolts or more and at wide open throttle you should have less than 4.8 volts and voltage should increase gradually as the throttle is opened. Also T/P sensor when put on should be able to move a few degrees, if it doesnt that try to put on outside of socket tangs than there should be a little tension when moved.[/quote:d06a7d8b89] All these things check out good. I did notice when the pickup was running i beat on the converter and it started running better do you think it might be stopped up?
Sep 24, 2007 at 1:19 PM
