Vehicle starts and rev's up fine...upon putting it into gear and placing torque upon the motor while driving, the engine dies...have replace PCM, crank sensor, cam sensor, plugs, wires, cap and rotor, and coil. Engine is a 5.2. Upon shutting off key, the engine will restart and process starts all over. the more the process is repeated, the sooner the engine dies. There are no codes...it seems the crank sensor looses signal shutting of ASD relay...
If you have question...970-879-5476
"UPDATE" Flashing codes found, 21, then 55
Apr 1, 2010 at 10:49 AM
