1995 Dodge Truck Transmission lines
192,000 MILES • 6 CYL • 2WD • AUTOMATIC
KAVEMANRACING
How do you repair the seals where the lines come together just before the radiator? It started leaking.
Nov 8, 2010 at 7:27 AM
CARADIODOC
  • 34,413 POSTS
There was a recall on these lines. The connectors are quick-connect fittings. They have o-rings inside but as I recall, the potential problem was where the rubber hose was crimped to the hose fitting. Those crimps leaked and they were worried about the leak causing a fire. I've never heard of that happening, but check with the dealer. Parts replaced under a safety recall used to get a lifetime warranty by Chrysler. I don't know if they still do that or if it only applies to the original owner.
caradiodoc
Nov 12, 2010 at 8:08 PM
KAVEMANRACING
It looks like the o'ring that is leaking and not where it's crimped. Thanks for responding.
Nov 12, 2010 at 10:43 PM
