1995 Dodge Truck Temp Sensor Location
1995 DODGE TRUCK
130,000 MILES • V8 • 2WD • AUTOMATIC
JIM.STILLWELL
I have a 1995 Dodge 1500 Ram pick-up. 5.2 liter fuel injection. It has a bad flat spot when at a normal driving speed. When you give it gas it stumbles and backfires through the throttle plenum and exhaust then takes off. It does this intermittent but more than less. It has all the characteristics of a bad temperature sensor but I am unable to locate it. It is not on the intake anywhere. Can you help me find the location.
Jul 21, 2008 at 9:16 AM
BMRFIXIT
  • 19,053 POSTS
you have a bad o2 sensor
its not the coolant temp sensor
i would check and replace O2 sensors
Jul 25, 2008 at 10:46 PM
