1995 Dodge Truck no spark
30,000 MILES • V8 • 4WD • AUTOMATIC
BIGBOB42
replaced the coil and ignition module..still no spark from distributor
Dec 19, 2009 at 2:27 AM
JDL
  • 16,098 POSTS
Welcome to the forum, did you check for trouble codes? You should be able to get mil codes by cycling the ignition switch, you just cycle the key till the dash lite comes on, no further, on--off, 0n--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
With engine cranking, did you check for primary voltage at the coil and injectors, dark green wire with orange tracer?
Dec 19, 2009 at 3:24 AM
