1995 Dodge Truck missing or bogging out
1995 DODGE TRUCK
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
EWDAWG
im having trouble i driving down the road and the truck starts to sputter like its missing or lacking gas then i press the gas pedal a little and it stops i changed the plugs wires cap rotar button and no help
Oct 6, 2009 at 2:23 PM
  • 110,244 POSTS
I would start by checking for vacuum leaks and then fuel pressure. Chances are there is a vacuum leak or a problem with the EGR sticking. Make sure it isn't plugged with carbon. Also, make sure the fuel pressure is good.
Here is a how to for checking fuel pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Oct 7, 2009 at 3:29 AM
