1995 Dodge Truck Can you help!!!! ahhhhhhh
15,000 MILES • V8 • 2WD • AUTOMATIC
SAINT1969
my 95 dodge pick up starts up fine,idles fine,but when put it into drive and drive down the road it seems to back fire through the carb.,,,? almost like a pop corn maker?,,,I tried dry gas, spray cleaning carb I have know idea what this could be? I dont want to take it in if its a simple fix ,I tried to make sure all wires are tight on dist cap,and plugs. I dont get it,
Dec 1, 2009 at 3:17 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Did you check valve timing and spark timing? Are there any trouble codes? Possible vacuum leak?
Dec 1, 2009 at 3:22 AM
