1994 Dodge Truck over heating no heat
153,000 MILES • V8 • 2WD • AUTOMATIC
MIK32742002
i changed water pump first had radiatior leak put in stopleak lost my heat changed radiatior and thermistat still have no heat and doesnt seem to be circulating i have no colapsed houses and no water or antifreeze in oil and no water coming out of tail pipe
Feb 21, 2009 at 7:31 AM
HOGGHARLEY
by a flush kit frm wallmart for abought 4 bucks it goes to 1 of your heater hoses flush it your heater core may be plugged flush it till you got clean water comeing out drain radiator then pull bottom radiator hose off on radiator drain water put it back on put the flush kit on hook up a gardne hose up start truck take radiaotr cap off let water come out till you see its comeing nice and clear take flush kit off pull bottom radiaotr off not of the engine of the radiator let it drain on my 96 it takes 2 1/2 gals of antifreeze go to autozone .com and find out how much antifreeze your truck takes they have a free specks chart just for your trk all you do is register your truck you will like this site its free frm hoggharly@comcast.net john let me know what happens good luck
Feb 23, 2009 at 1:35 AM
