1994 Dodge Truck location of fuel filter
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROSEMARYROBERSON
engine started to sputter then stalled. waited about 15 min started back up died again. had it towed home. poured lucas injection cleaner in it. it has been running better, but still sputters once in awhile. trying to start w/ cheapest as i cant afford$500 fuel pump. where is the fuel filter located? i do run the tank low on gas every 2 wks. i hope you can give me an idea. thanks , rosemary
Apr 10, 2009 at 5:46 AM
JDL
  • 16,098 POSTS
Hello, my info says the right side of engine compartment. To me, the right side is the passenger side. Sometimes these databases are wrong, follow the fuel line.
Are there any trouble codes?
Apr 10, 2009 at 6:25 AM
SOUP63
The filter for some of those trucks was IN the fuel pump. Mine is. But it's a 95.
Aug 20, 2009 at 8:44 AM
