Under vehicle, driver side, below bed area, driver side of fuel tank, mounted on frame rail in fuel line. there is a couple of ways to relieve pressure in the lines .I like to take the fuel pump fuse out of the fuse compartment then start the car and let the fuel run out of the lines. open the gas cap to relieve any residual gas and fumes. then go by some quick diconnect couplings for your specific vehicle and remove the filter. replace in reverse sequence.
Mar 2, 2008 at 1:42 AM
