1994 1/2 truck 5.9 160000 miles
LASH4567
  • 1994 DODGE TRUCK
2 weeks ago I went to crank my truck and it would not crank. Discovered I was not getting spark so I changed the cap and rotor, both needed changing. Still had no spark so I check for voltage to coil and have no voltage to coil. Traced wires back to computer and ohmed wires out, good. I check for volatage going to computer and I have battery voltage going to computer. Is the computer bad or could it be something else?
Monday, November 12th, 2007 AT 6:57 PM
BMRFIXIT
  • 19,053 POSTS
Did u check the relay
ASD relay
check/replace crank sensor
good luck
Monday, November 12th, 2007 AT 7:18 PM
